MadTom
Check wires between ECU and injectors. Often pins in connector of the injector loom went bad, loosing contact. I have repaired several of these just by tightening these pins. Bad contact leads to open circuit.
This has no direct connection to crank position sensor. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
25th Mar 2025 9:34am |
Chizzle
Thanks, I will take a look
25th Mar 2025 12:31pm |
