Home > Td5 > High speed crank sync lost fault + Injector 3 open circuit
Chizzle
United Kingdom 2006 Defender 90 Td5 PU Belize Green
I HAD a problem with my throttle completely cutting out after a high acceleration. Narrowed it down to dodgy wiring from the Crank Position Sensor.
Put a new sensor in + Loom from Empire tuning.
Managed a 5 hour motorway drive (x2) no problems. About a week later, I drove for 10 minutes on the Motorway, suddenly starts to run really rough, MIL light + black smoke out the back. (was going 55mph)
Turned ignition on and off, runs and idles fine. No sign of a misfire (also no misfire code)
Did a code read and got these:
- High speed crank synchronisation Lost fault
- Injector 3 Open Circuit Detected.
Starts perfectly & runs perfectly at low speed/low temp.
Not had problems with Injectors before. Could this be a dodgy Crank Position Sensor? Or is there something worse going on?
I'm running a 2006 Def 90 TD5 @ 178,000
Cheers,
Charlie
Post #1063763 24th Mar 2025 5:41pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Check wires between ECU and injectors. Often pins in connector of the injector loom went bad, loosing contact. I have repaired several of these just by tightening these pins. Bad contact leads to open circuit.
This has no direct connection to crank position sensor. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1063814 25th Mar 2025 9:34am
Chizzle
Thanks, I will take a look Thumbs Up
Post #1063834 25th Mar 2025 12:31pm
