Home > In Car Electronics > HELP - Speaker Size for lower Dashboard
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey friends I am in the process of ordering parts to put a stereo in my D90. Mine is older and does not have speakers in the lower dash and I plan on adding them. I know clearance can be an issue so I already have designed some 3d printable spacers to take care of depth clearance.
However my main question is what diameter. I have a pair of 4" and 5.25" on order. What would you recommend? Thank you 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #1063762 24th Mar 2025 4:49pm
bodstruck
I have just replaced mine with 4" which is the same as was originally in there. If you are retro-fitting then 5 1/4" may fit but it may be tight.
Post #1063781 24th Mar 2025 8:08pm
Soulrider911
Thank you so much 1989 Defender 90
Post #1063801 24th Mar 2025 10:15pm
donmacn
I think 4” will fit without spacers, but the 5.25” will need them. I started with the smaller ones, but moved on to the 5.25”.
Whichever side has the wiper motor is the issue. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1063804 24th Mar 2025 11:06pm
Soulrider911
Thank you Donald, this is exactly the comment I was looking for, as I will have to cut holes and would like to do it once... I can easily make a spacer to push out the 5.25'. Cheers! 1989 Defender 90
Post #1063861 25th Mar 2025 5:30pm
