![]() | Home > In Car Electronics > HELP - Speaker Size for lower Dashboard |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1007 ![]() ![]() |
I have just replaced mine with 4" which is the same as was originally in there. If you are retro-fitting then 5 1/4" may fit but it may be tight.
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 119 ![]() ![]() ![]() |
Thank you so much 1989 Defender 90
2022 Defender 110 SE DIY’er | Always learning |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
I think 4” will fit without spacers, but the 5.25” will need them. I started with the smaller ones, but moved on to the 5.25”.
Whichever side has the wiper motor is the issue. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thank you Donald, this is exactly the comment I was looking for, as I will have to cut holes and would like to do it once... I can easily make a spacer to push out the 5.25'. Cheers! 1989 Defender 90
