![]() | Home > Technical > TD5 Alternator Connector |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6024 ![]() ![]() ![]() |
I found the connector lead quite short as well and also a pain in the ass to unplug. I used plenty of contact cleaner to try and blast away any crud. 1999 Defender TD5 110
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
If you choose to cut and lengthen the item you need is available as part YPC10604 or this item on the jungle website
https://www.amazon.co.uk/Defender-Discover...B0C1KV7151 |
Dr Phibes Member Since: 24 Apr 2024 Location: Melbourne Posts: 71 ![]() ![]() |
Thanks. I have one of those on order. I am away from the vehicle at present but think there must be some crap stuck in the old one. I did spray it but will try again before cutting it.
I had a lot of crud in my connector. To make the amazon one better, if you could get the plug for the other end then you could extend without having to cut wires. 1999 Defender TD5 110
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
![]() YPC10604 TD5 Alternator Connector - https://www.ebay.co.uk/itm/155677596770 Mating Male Connector for YPC10604 - https://www.ebay.co.uk/itm/153503087058 I can also supply these as a male to female extension in the correct wire colours and gauge, to whatever length is required. PM here is cheaper than through eBay. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Thanks but I’m in Australia and they are pretty cheap here
Of course
![]() Also available as Toyota/Lexus Part No. 90980–11349 Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
What happens if the connector/cable fails? Does it just give a false warning on the dash, with the battery happily charging of the main alternator feed?
