Home > Technical > TD5 Alternator Connector
Dr Phibes
Australia
Hi All,
I’m struggling to reconnect the Denso 3 pin connector (IR11?) to a brand new alternator (correct model, same connector). The pins look OK but it is very hard to see the connector and the lead is short. Has anyone had the same problem?
Thinking I might cut it and lengthen so it’s easier to work with. Possibly solder a new connection on.
Lee
Post #1061908 3rd Mar 2025 10:47pm
excossack
I found the connector lead quite short as well and also a pain in the ass to unplug. I used plenty of contact cleaner to try and blast away any crud. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1061947 4th Mar 2025 9:16am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
If you choose to cut and lengthen the item you need is available as part YPC10604 or this item on the jungle website
https://www.amazon.co.uk/Defender-Discover...B0C1KV7151
Post #1061962 4th Mar 2025 11:01am
Dr Phibes
Australia
Thanks. I have one of those on order. I am away from the vehicle at present but think there must be some crap stuck in the old one. I did spray it but will try again before cutting it.
Post #1061969 4th Mar 2025 1:41pm
excossack
I had a lot of crud in my connector. To make the amazon one better, if you could get the plug for the other end then you could extend without having to cut wires. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1061972 4th Mar 2025 2:21pm
PaulMc
Whistle
YPC10604 TD5 Alternator Connector - https://www.ebay.co.uk/itm/155677596770
Mating Male Connector for YPC10604 - https://www.ebay.co.uk/itm/153503087058
I can also supply these as a male to female extension in the correct wire colours and gauge, to whatever length is required.
PM here is cheaper than through eBay. Paul.
Post #1061977 4th Mar 2025 4:00pm
Dr Phibes
Australia
Thanks but I’m in Australia and they are pretty cheap here
Post #1062005 4th Mar 2025 8:24pm
PaulMc
Of course Thumbs Up
Also available as Toyota/Lexus Part No. 90980–11349 Paul.
Post #1062035 5th Mar 2025 1:07am
Dr Phibes
Australia
What happens if the connector/cable fails? Does it just give a false warning on the dash, with the battery happily charging of the main alternator feed?
Post #1062038 5th Mar 2025 7:44am
