Home > In Car Electronics > Winch to battery terminals help please
mcma1
So I have the LR Warn 9.5 cti kit which so far I have only run the main cables to the battery box and now need to connect the winch power to the battery using the cut off solenoid kit. What is the best way to connect the heavy winch cables to the battery? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1059194 1st Feb 2025 8:44pm
landy andy
Isolator on the front of battery box is always the way I’ve done it. Easy. Reliable and bypassable if required.
Post #1059197 1st Feb 2025 8:51pm
mcma1
Thanks but I am actually trying to understand the best way to connect the cables onto the battery terminals? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1059198 1st Feb 2025 8:53pm
mcma1
so I just found this picture on here which is what I am trying to replicate. So I can bolt the negative onto the chassis? The Land Rover fitting instruction had me a bit confused.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1059201 1st Feb 2025 9:08pm
I would strongly recommend that you replace the rather feeble and unsatisfactory original equipment battery terminal connectors with decent ones such as these:
https://pbautoelectrics.co.uk/shop/auto-ma...mm-bt461p/
The standard connectors are unbelievably unsatisfactory in almost every respect and it beats me why Land-Rover has for decades used them.
Post #1059204 1st Feb 2025 9:17pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
I guess many will have done it differently but what I did was..
Main winch positive direct to cut off solenoid then a cable to the battery +
Main winch earth is run to the bolt under the seatbox that picks up the chassis to battery earth.
The battery terminals are the above post style and I re crimped the existing cables.
I didn't want a hole in the seatbox for an old style isolator switch, and the Tin can solenoids are IMO not man enough for winching loads. So i stuck a Su280 Albright in there and wired a dash switch.
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1059208 1st Feb 2025 9:57pm
NickMc
Andy you can get all this stuff from LA distribution in Bloomfield commercial centre.
Post #1059219 1st Feb 2025 11:46pm
