![]() | Home > In Car Electronics > Winch to battery terminals help please |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
So I have the LR Warn 9.5 cti kit which so far I have only run the main cables to the battery box and now need to connect the winch power to the battery using the cut off solenoid kit. What is the best way to connect the heavy winch cables to the battery? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Thanks but I am actually trying to understand the best way to connect the cables onto the battery terminals? Andy
so I just found this picture on here which is what I am trying to replicate. So I can bolt the negative onto the chassis? The Land Rover fitting instruction had me a bit confused.
![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
I would strongly recommend that you replace the rather feeble and unsatisfactory original equipment battery terminal connectors with decent ones such as these:
https://pbautoelectrics.co.uk/shop/auto-ma...mm-bt461p/ The standard connectors are unbelievably unsatisfactory in almost every respect and it beats me why Land-Rover has for decades used them. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
I guess many will have done it differently but what I did was..
Main winch positive direct to cut off solenoid then a cable to the battery + Main winch earth is run to the bolt under the seatbox that picks up the chassis to battery earth. The battery terminals are the above post style and I re crimped the existing cables. I didn't want a hole in the seatbox for an old style isolator switch, and the Tin can solenoids are IMO not man enough for winching loads. So i stuck a Su280 Albright in there and wired a dash switch. ![]() Click image to enlarge ![]() Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Andy you can get all this stuff from LA distribution in Bloomfield commercial centre.
