Home > 130 > Rear tub weight?
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Rear tub weight?
Hi All,
Just wondered if anyone had either weighed or lifted their rear tub (standard 130 hicap tub) without a telehandler/forklift etc.
Mines now at the stage of needing to come off for some MOT repairs to the brackets/crossmember etc and wondering how many people I need to find to help lift it Wink
Thanks all
Post #1058810 28th Jan 2025 6:18pm
Two people can lift a SWB or LWB tub without difficulty (it isn't heavy, just unwieldy) and I can't imagine that a 130 hi-cap tub is significantly different.
Post #1058813 28th Jan 2025 7:04pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
It took 3 of us to lift a 110 Utility tub on but 4 to loft it off with storage lockers and shutters in place so I'd think you'd be ok with 3 to 4 people depends on strength. Finding something suitable to hold onto is the hardest part 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1058817 28th Jan 2025 7:29pm
Storage lockers, shutters, and presumably a roof structure will add very considerably to the mass. My impression from the OPs question is that he is just removing a standard rear buck.
Post #1058818 28th Jan 2025 7:35pm
34064
Sorry black wolf should of worded it better with sides shutters and lockers in took 4 of us but took 3 of us to get the bare tub back on. Not sure of the weight of a 130 tub so just giving an insight though I do really fancy a 130 one day 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1058819 28th Jan 2025 7:40pm
Thumbs Up
Post #1058828 28th Jan 2025 8:01pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I believe the Tub = 125kg, I suggest you remove the tail gate first to reduce the weight a bit 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #1058845 29th Jan 2025 12:27am
benspray
excellent, thanks all, at that kind of weight may be best with 3 then Smile
Post #1058870 29th Jan 2025 12:47pm
