![]() | Home > 130 > Rear tub weight? |
Two people can lift a SWB or LWB tub without difficulty (it isn't heavy, just unwieldy) and I can't imagine that a 130 hi-cap tub is significantly different.
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 230 ![]() ![]() ![]() |
It took 3 of us to lift a 110 Utility tub on but 4 to loft it off with storage lockers and shutters in place so I'd think you'd be ok with 3 to 4 people depends on strength. Finding something suitable to hold onto is the hardest part 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
Storage lockers, shutters, and presumably a roof structure will add very considerably to the mass. My impression from the OPs question is that he is just removing a standard rear buck.
Sorry black wolf should of worded it better with sides shutters and lockers in took 4 of us but took 3 of us to get the bare tub back on. Not sure of the weight of a 130 tub so just giving an insight though I do really fancy a 130 one day 110 Td5 Ex Utilities slowly converting into a pop top camper one day
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 693 ![]() ![]() ![]() |
I believe the Tub = 125kg, I suggest you remove the tail gate first to reduce the weight a bit 130 Puma HCPU with an Artica 240LR Demountable Camper
benspray Member Since: 31 Jul 2014 Location: Norfolk Posts: 165 ![]() ![]() ![]() |
excellent, thanks all, at that kind of weight may be best with 3 then
