![]() | Home > Wheels & Tyres (L663) > Tyres in I663 275/60/20 |
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
I fiited this size and they're perfect. They fill the arches like the factory tyres should have. I have fitted the genuine factory Land Rover mudflaps and wheel arch extensions prior to having the new tyres fitted and they all compliment each other well.
![]() Click image to enlarge No wheel-spacers needed. No rubbing. Speedo is now correct (UK standard settings). The gearing appears to be unaffected too. ![]() Click image to enlarge ![]() Click image to enlarge |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 370 ![]() ![]() |
Thank you very much for your kind and prompt response!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 39 ![]() ![]() |
That does look very good on 275's BadgerWaz
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 318 ![]() ![]() |
Looking good! No rubbing off road or at full lock?
No not at all. The BFG's have quite a hard tread but with the extra inch height I'm sure it'll even itself out.
I think the 110 looks juicy now. Last edited by BadgerWaz on 27th Dec 2024 2:00am. Edited 1 time in total |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 58 ![]() ![]() |
When you say the speedo is now correct, what was the problem before and what tyres were you using? TIA. |
That it now no longer under-reads. Manufacturers set these below the actual speed shown in the cluster (a set tolerance) to accomodate different size wheels/tyres/pressures so you're never actually driving at 60 when the speedo says it's 60 (more like 57).
You can correct this using IIDG4 but I never bothered. With my larger tyres my speedo now matches gps perfectly, so 30 is 30 (not 27.5 mph) etc. ![]() 255/60/20 factory size previously. |
Ah - ECE Regulation 39.
Was wondering if there was a specific JLR-related problem... |
Eric Caterpillar Member Since: 17 Jun 2024 Location: West of Scotland Posts: 80 ![]() ![]() |
I really like the look of that setup, looks mean, but in a purposeful way.
Interestingly, you said that the 275/60/20 doesn't rub anywhere, I found a post somewhere else saying that it did. I am looking for getting a second wheel + tyre set for any winter/off road driving and weighing in all the tyre setups: 255/60/20 275/55/20 and now also 275/60/20 Depending on a tyre availability. |
Mine don't rub on anything.
8.5" wheel diameter. Used offroad. Coil springs. |
STXdefender90 Member Since: 27 Feb 2025 Location: San Antonio Posts: 4 ![]() ![]() |
Man! This looks great. Can I ask? Does your defender have the adjustable suspension ??
Any luck on finding the perfectTire/size?
I too am considering the 275/60/20 The guy on this thread that successfully managed this size states he has stock 8.5 inch wide 20’rims, I’m wondering if a 20 x 9.5 will allow for the same tire size? Any input you could provide would be appreciated! Thanks in advance ![]()
Garthlands Member Since: 01 Dec 2021 Location: Glasgow Posts: 27 ![]() ![]() |
I'm running 275/55/20, on air suspension and no rubbing anywhere, and believe me I've had the suspension fully articulated often enough to have confidence in saying that!
At least in the UK, that would be the choice ig I were to go the 275/55/20 route:
![]() Click image to enlarge Haven't decided what to do just yet, wanted a nice winter rated set, think my preference would be a 275/55 over a 275/60 as I would want to avoid any unpleasant surprises with too large a diameter. Lastly, the OEM 255/60 range has a very limited choice.
