Home > Wheels & Tyres (L663) > Tyres in I663 275/60/20
ruben
Spain
Hi to all!
Does anyone know if it is possible to install it on I663 110 23 MY I6 D MHEV without modifying anything in the wheel arches or installing spacers?
Thanks in advance!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1054149 8th Dec 2024 2:11pm
BadgerWaz
I fiited this size and they're perfect. They fill the arches like the factory tyres should have. I have fitted the genuine factory Land Rover mudflaps and wheel arch extensions prior to having the new tyres fitted and they all compliment each other well.
No wheel-spacers needed.
No rubbing.
Speedo is now correct (UK standard settings).
The gearing appears to be unaffected too.
Post #1054152 8th Dec 2024 2:55pm
ruben
Spain
Thank you very much for your kind and prompt response!! Defender 110 SE I6 D250 23MY
Post #1054154 8th Dec 2024 3:18pm
91dm
Ireland
That does look very good on 275's BadgerWaz
Post #1054169 8th Dec 2024 5:30pm
Crazymind
Looking good! No rubbing off road or at full lock?
Post #1054209 8th Dec 2024 10:42pm
BadgerWaz
No not at all. The BFG's have quite a hard tread but with the extra inch height I'm sure it'll even itself out.
I think the 110 looks juicy now.
Post #1054216 9th Dec 2024 12:46am
F-Typical
No rubbing.
When you say the speedo is now correct, what was the problem before and what tyres were you using?
TIA.
Post #1054236 9th Dec 2024 11:41am
BadgerWaz
That it now no longer under-reads. Manufacturers set these below the actual speed shown in the cluster (a set tolerance) to accomodate different size wheels/tyres/pressures so you're never actually driving at 60 when the speedo says it's 60 (more like 57).
You can correct this using IIDG4 but I never bothered.
With my larger tyres my speedo now matches gps perfectly, so 30 is 30 (not 27.5 mph) etc.
Sheep
255/60/20 factory size previously.
Post #1054291 9th Dec 2024 11:21pm
F-Typical
Ah - ECE Regulation 39.
Was wondering if there was a specific JLR-related problem...
Post #1054293 9th Dec 2024 11:53pm
Eric Caterpillar
I really like the look of that setup, looks mean, but in a purposeful way.
Interestingly, you said that the 275/60/20 doesn't rub anywhere, I found a post somewhere else saying that it did. I am looking for getting a second wheel + tyre set for any winter/off road driving and weighing in all the tyre setups:
255/60/20
275/55/20
and now also
275/60/20
Depending on a tyre availability.
Post #1054327 10th Dec 2024 11:39am
BadgerWaz
Mine don't rub on anything.
8.5" wheel diameter.
Used offroad.
Coil springs.
Post #1054393 11th Dec 2024 12:02am
STXdefender90
Man! This looks great. Can I ask? Does your defender have the adjustable suspension ??
No rubbing.
Post #1061495 27th Feb 2025 7:44am
STXdefender90
Any luck on finding the perfectTire/size?
I too am considering the 275/60/20 The guy on this thread that successfully managed this size states he has stock 8.5 inch wide 20’rims, I’m wondering if a 20 x 9.5 will allow for the same tire size? Any input you could provide would be appreciated!
Thanks in advance
Razz
255/60/20
275/55/20
and now also
275/60/20
Post #1061499 27th Feb 2025 8:45am
Garthlands
I'm running 275/55/20, on air suspension and no rubbing anywhere, and believe me I've had the suspension fully articulated often enough to have confidence in saying that!
Post #1061507 27th Feb 2025 11:20am
Eric Caterpillar
At least in the UK, that would be the choice ig I were to go the 275/55/20 route:
Haven't decided what to do just yet, wanted a nice winter rated set, think my preference would be a 275/55 over a 275/60 as I would want to avoid any unpleasant surprises with too large a diameter.
Lastly, the OEM 255/60 range has a very limited choice.
Thanks in advance
Razz
255/60/20
275/55/20
and now also
275/60/20
Post #1061515 27th Feb 2025 1:09pm
