![]() | Home > Maintenance & Modifications > Winch Question/opinions |
8274
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
I've always had a Warn HS9500i ... Very good!
But I have two friends that have/had 8274 for over 10 yrs and they're great ... never broke down! they're serviced regualrly and work fine ... about the hidraulic one never tried Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
given the choice, the hydraulic.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
If its for work,, trees etc,, i would say hydraulic , will just pull all day, look at Mile Marker, or Red Winch
Have 4 or 5, 8274's from bog std, to twin overvolted motors ones, great winch for competition !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Well if you have a hydraulic winch you need drive and space to put it! (resivor etc)
Electric is more compact and can run without drive! As you say both are good in different ways. Will the hydraulic work if you tair a line? Will the electric work is some one nicks the motor? Russell 2011MY 110 XS USW Black |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Hydraulic all the way.
Why would you tear a line? Anymore than if you tore a power cable?? If not hydraulic then pto mechanical winch is just the dogs danglies |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8383 ![]() ![]() ![]() |
hydraulic for commercial ie tree pulling
8274 for competition as its versatile ans spares are easy to come by tds for anything else. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
