![]() | Home > Puma (Tdci) > Dials misbehaving when turning ignition off |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8341 ![]() ![]() ![]() |
Multi plug on the back is fitted correctly?
No chaffing anywhere? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Richard D Knight Member Since: 21 Sep 2018 Location: Hoedspruit Posts: 3 ![]() ![]() ![]() |
Hi James
It's in the garage at the moment, so I will forward on Thanks 👍🏻 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6687 ![]() ![]() ![]() |
You don't have the permanent 12V supply to the cluster, so the cluster loses power instantly when ignition switch off and is "frozen".
Normally, the cluster has permanent 12V power and can gracefully park the needles when ignition switched off. Check fuse 30 which supplies permanent 12V to pin 1 of the cluster (purple+brown wire). Martin ![]() ![]() |
Brilliant
Thanks all sorted now 🙂 |
What was it?
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
What was it? Puma 110" SW
