Home > Puma (Tdci) > Dials misbehaving when turning ignition off
Richard D Knight
South Africa 2005 Defender 110 Td5 SW Corris Grey
Hi all
Apologies I've had a good search and can't find a similar issue.
I have a 2009 puma.
Sometimes the dials do not reset when I turn off the ignition. The fuel gauge, temp gauge will stay in their position as if the ignition is on and the rev counter will sit at c. 1000 rpm
By cycling the ignition once or twice they will reset
I did lose all dials once when driving and the defender went to limp mode.
Would you advise sending the cluster in or could it be something else?
Thanks
Ps my profile says I'm in South Africa but I am back in the UK now
Post #1037709 17th Jun 2024 8:29pm
jst
Multi plug on the back is fitted correctly?
No chaffing anywhere? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1037714 17th Jun 2024 9:04pm
Richard D Knight
Hi James
It's in the garage at the moment, so I will forward on
Thanks 👍🏻
Post #1037717 17th Jun 2024 9:23pm
Martin
Site Admin
You don't have the permanent 12V supply to the cluster, so the cluster loses power instantly when ignition switch off and is "frozen".
Normally, the cluster has permanent 12V power and can gracefully park the needles when ignition switched off.
Check fuse 30 which supplies permanent 12V to pin 1 of the cluster (purple+brown wire).
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1037724 17th Jun 2024 11:25pm
Richard D Knight
Brilliant
Thanks all sorted now 🙂
Post #1037816 18th Jun 2024 8:37pm
Martin
Site Admin
What was it?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1037818 18th Jun 2024 8:45pm
MK
What was it? Puma 110" SW
Post #1037819 18th Jun 2024 8:51pm
