![]() | Home > Puma (Tdci) > Advice air flow. |
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 77 ![]() ![]() ![]() |
Advice have a better engine flow do l need to change the EGR and the intercooler is the anything else ?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
The biggest difference you can make is to change the wing to air-box intake duct. The current one is highly restrictive. Next you can modify the existing airbox. If you are changing the intercooler then replacing the existing intercooler hoses with silicon ones would be a good idea.
Have a read of this topic. https://www.defender2.net/forum/topic46581.html?highlight=nugget And this one https://www.defender2.net/forum/topic25864.html Deleting the EGR won’t give you better airflow, but will stop your engine, in particular the inlet manifold, gunking up. Noting easier to do on a 2.4, complex on a 2.2 as requires DPF removal as well. To delete you will need an engine ECU map. Intercooler upgrade on a std map won’t make much difference, unless you are working hard in a hot climate. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 818 ![]() ![]() |
hi Ian, ill just add a little to the egr on the 2.2, as its something I was checking up on the other day ..
this is with a bas map and dpf delete... if that is done then the egr valve is effectively shut, but it still has to have an electrical connection maintained as disconnecting may cause issues elsewhere.. not sure what a delete would involve but I was told that without the electrical connection id likely get issues, |
it was Peter I was talking to Ian, and I was confused by the term delete... on my m7 transit which had a 2.4 engine I got a egr delete.. that allowed me to disconnect it , but I did leave it in place..
im been told to leave electrically connected and leave well alone on the defender even if it isn't working so im going along with that... ![]() edit.. the other thing which was causing me some confusion, was the fact that there are patches for both egr and dpf sold separately on the site.. |
Some 2.2’s were rest of world spec without DPF, so perhaps that’s why DPF and EGR options are available separately.
Cheers |
Thank you for reply. |
So is there bolt on kit for it.?
