Home > Puma (Tdci) > Calling all DC owners....help request.
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
I'm looking for some help please fellas.....I've noticed my DC 'lists' to one side at the front. I've measured the distance between teh ground and the wheel arch on each side, and it turns out the drivers side front is 30mm closer to the ground than the passenger side!
Been to my local dealer (it's a March 2011 vehicle) and they started off with the usual "they all do that" until I asked the workshop 'controller' which side is supposed to be higher and he answered that normally the dirvers side is marginally higher than the passenger to allow it to balance out when the driver gets it. I personaally think it sounds like boll-ocks (pardon my language).
Anyway, they're coming to pick it up from me this Friday (as I didn't really want to pay the £25 for a courtesy car!!!) to 'take some measurements' and ask Land Rover if they are within tolerance. To be fair, the workshop guy did think that 30mm did seem excessive.
Any chance you chaps could measure the O/s & N/s heights from the floor, to see if there are any differences please? Just to give me some 'ammunition', should I need it.
Thanks guys Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #99875 14th Nov 2011 3:04pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Mines spot on though it is a td5 Thumbs Up
Post #99878 14th Nov 2011 3:13pm
pom
why not check the ones on their forecourt ?
Pom
Post #99880 14th Nov 2011 3:29pm
ibexman
Weak spring one side?? broken spring? bent chassis needs a good look at
Post #99885 14th Nov 2011 3:43pm
MuddyMarky
Good idea Pom......hadn't thought of that one!
Weak/broken spring was my first thought......might go back up there with a tape measure I think!
So, one here is spot on....be good to see what others find. Thanks so far Smile
ALSO.....forgot to say above....had a quick look at their fixed price servicing list up on the wall: £450 for 12 month /12k mile service! lol No wonder I'm not going there for that!! Can't remember the exact figure, but in excess of £560 for the 24 month/24k service.......completely shocking! Mark
2011 110 XS DC
Stornoway Grey
Post #99887 14th Nov 2011 3:49pm
ibexman
Measure the difference between upper and lower spring seats Thumbs Up
Post #99890 14th Nov 2011 3:52pm
Surrey Rover
Firstly I don't have a DC, but my 90 pickup lists. In fact I think all my Defenders have been slightly lower on the N/side than the O/side.
I did question it once and was told the "It's to balance the weight of the driver" but never thought much more of it. I will measure mine tonight to check the difference. Nick
2.2 110 Tipper
Post #99903 14th Nov 2011 4:51pm
Not sure about the rears off-hand, but LR front springs have always been handed to take account of the driver and, in pre-'07 90s', the fuel tank. Therefore, the drivers side usually sits slightly higher when unladen. The drivers side being lower at all is definitely wrong, let alone by 30mm. Darren
Post #99906 14th Nov 2011 5:02pm
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I also heard this, that the driver side springs are slightly longer, so perhaps your springs have been put on the wrong side following a LHD set-up Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #99909 14th Nov 2011 5:14pm
22900013A
If you had to pay £25 its not a courtesy car then is it? :p 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #99917 14th Nov 2011 6:00pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Mine didn't have that problem, or at least never noticed it, and still don't ... April 2010 vehicle ...
It was lower at the front end, after fitting winch and bumper it was even lower ... fitted some original HD springs and it's fine ... it is leveled - back and front, left and right ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #99919 14th Nov 2011 6:41pm
bob neville
Hi Mark
Had exactly the same problem, Yeovil LR found the problem very quickly - two nearside front springs fitted instead of the correct 'handed' springs Shocked
They changed them and problem resolved, however the problem has returned after a year or so Big Cry
I'm going to change the front springs to Flatdog HD non lift version myself, one of the many jobs on my list.
I know everybody says that LR springs are OK but, in my experience, they do tend to sag after a sort period of time.
Bob
PS - have a look here for the correct colour codes.
http://rovers.red90.ca/springinfo.html
Post #99937 14th Nov 2011 7:46pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Mine sits level ish look at the spring colours mine are different
Post #99955 14th Nov 2011 9:26pm
Bill
Ireland 2008 Defender 90 Puma 2.4 XS CSW Java Black
just checked, mine is also level. 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #99971 14th Nov 2011 10:21pm
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
As of TD5 vehicles, LR stopped fitting handed springs to the front - mine had yellow/yellow on both sides whereas previous vehicles would have had different springs.
I am not sure if they started fitting handed springs to pumas again, but I very much doubt it. [:O|===|O:] 2001 110 TD5 Doublecab
Post #99975 14th Nov 2011 10:29pm
