Home > Puma (Tdci) > Front output seal |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3210 |
The transfer box on the Puma is already nose up, so front output is a bit higher than the rear. Doing it on an incline would help loosing less oil, nut be sure you are working safe.
You will probably find that the splines are glued, but easy enough to pull the flange with a 2 or 3 legged puller. At £60 I would buy the complete kit. The old seal may have worn the sealing face on the old flange. Clean up all old residue of Loctite from the male splines. I still like to re apply new loctite when fitting, but is not really necessary as long as you use the correct felt washer under the nut/washer. It is an easy job. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
28th Mar 2024 11:12pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 795 |
get the right spanner for the nuts 9/16 ring, not enough room for open end or standard socket and you will round the nuts easily which will take you a lot longer to complete the job.
Or you get the 'special socket' which works as well but is a bit of a fiddle. For sure you want to lift one front wheel so you can spin the wheel to position the tool (then block the wheel with your foot so you can apply force) |
29th Mar 2024 8:35am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16883 |
If you use a ring on the shaft side of the flange and an OE on the box side you have full control without having to use your foot as a chock.
29th Mar 2024 10:27am |
DJow Member Since: 29 Oct 2023 Location: Yorkshire Dales Posts: 12 |
Thanks for the tips, much appreciated!
I realised i will have to drain the oil anyway as I have no way of knowing how much is in there! |
2nd Apr 2024 8:06am |
This is a good read for oil qty vs level... although it also does not hurt to drain the oil... do inspect the oil however for metal.
https://www.defender2.net/forum/topic56771.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
2nd Apr 2024 8:43am |
