Home > Puma (Tdci) > Front output seal
DJow
United Kingdom 2008 Defender 110 Puma 2.4 CSW Keswick Green
Front output seal
The front output seal on my transfer box is leaking so I’m going to have a bash at fixing it myself.
Does anyone have any specific do’s or do not’s whilst doing this? It looks fairly straightforward.
My main question is will i have to drop the oil out or could i have the car inclined to hold the oil in and top up after?
I’m looking at buying the rubber seal, fiber washer and a new nut. Though Gwynn Lewis do a full new flange kit with all the seals for £60, is it worth buying the whole assembly at that price?
Thanks
Post #1029666 28th Mar 2024 8:42pm
Dinnu
The transfer box on the Puma is already nose up, so front output is a bit higher than the rear. Doing it on an incline would help loosing less oil, nut be sure you are working safe.
You will probably find that the splines are glued, but easy enough to pull the flange with a 2 or 3 legged puller.
At £60 I would buy the complete kit. The old seal may have worn the sealing face on the old flange.
Clean up all old residue of Loctite from the male splines. I still like to re apply new loctite when fitting, but is not really necessary as long as you use the correct felt washer under the nut/washer.
It is an easy job. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1029689 28th Mar 2024 11:12pm
TexasRover
get the right spanner for the nuts 9/16 ring, not enough room for open end or standard socket and you will round the nuts easily which will take you a lot longer to complete the job.
Or you get the 'special socket' which works as well but is a bit of a fiddle.
For sure you want to lift one front wheel so you can spin the wheel to position the tool (then block the wheel with your foot so you can apply force)
Post #1029703 29th Mar 2024 8:35am
If you use a ring on the shaft side of the flange and an OE on the box side you have full control without having to use your foot as a chock.
Post #1029719 29th Mar 2024 10:27am
DJow
Thanks for the tips, much appreciated!
I realised i will have to drain the oil anyway as I have no way of knowing how much is in there!
Post #1030155 2nd Apr 2024 8:06am
Dinnu
This is a good read for oil qty vs level... although it also does not hurt to drain the oil... do inspect the oil however for metal.
https://www.defender2.net/forum/topic56771.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1030158 2nd Apr 2024 8:43am
