![]() | Home > Puma (Tdci) > Strange alarm fault |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Possibly water on one of the switches or dodgy bonnet switch?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
If you have a suitable diagnostic tool you can interrogate the alarm ECU and see what triggered it. Saves a lot of time.
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 242 ![]() ![]() ![]() |
Any recommendations?
My basic OBDII scanner isn't really cutting it at the moment and I need to upgrade, something that can put Electronic Parking Brakes in Maintenance Mode would be a great help. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20945 ![]() ![]() |
It’s common for them to play up, they are relatively cheap to replace which is why I have any suspicions I just replace them.
The bonnet item is not as cheap though. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
Alas, the issue has reappeared.
The rubber sleeve on the bonnet switch is perished and the plunger is wonky. Ordered a replacement (AMR2022) from John Craddocks eBay store £15 delivered (vs £46 if bought direct through their website). Hopefully this sorts the issue. 2011 CSW XS 90 |
