Home > Maintenance & Modifications > Condensation in Front Lamps
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Took the front 4 x clear round lenses off at the weekend, as they were full of condensation and have been for weeks. Dried them out in the house, put them back on only for the problem to re-occurr a few days later after light rain.
Back lenses are all ok. Is this a common problem?
I noticed the seal between the bulb holder and lense housing was made using cheap foam ring rather than a quality rubber seal, providing for a watertight lense Rolling Eyes
Post #98841 8th Nov 2011 9:24pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Are they aftermarket ones? The OEM clear ones on the front of my truck are fine, but the aftermarket (WIPAC?) clear indicators practically have goldfish swimming in them Rolling Eyes
Post #98845 8th Nov 2011 9:40pm
Martyn
Yep, they are original LR ones. Had the truck from new now... 4 months
Post #98847 8th Nov 2011 9:45pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Could it be that the condensation will be prominent at the front as the warm air generated from proximity to the engine will get into the lenses (through a poor bulb holder/lens assembly seal maybe) and then creates the condensation when it encounters the rush of colder air from the front as you drive??
I took all my original front and rear lenses off recently (6 year old td5) to clean/grease the electrical contacts. I didn't encounter any condensation issues but I did have the same flimsy foam seal you mention. I smeared a bit of ACF50 grease (the blue stuff - don't believe that this will degrade the foam) around the seal when re-assembling. Wasn't really thinking of condensation, just to improve the overall seal against the elements.
May be worth a go to try to combat the condensation issue too ? Jon - 110 td5 [sold]. Currently Defenderless.
Post #98862 8th Nov 2011 10:47pm
