Home > Maintenance & Modifications > Condensation in Front Lamps |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 652 |
Are they aftermarket ones? The OEM clear ones on the front of my truck are fine, but the aftermarket (WIPAC?) clear indicators practically have goldfish swimming in them
8th Nov 2011 9:40pm |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
Yep, they are original LR ones. Had the truck from new now... 4 months
8th Nov 2011 9:45pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Could it be that the condensation will be prominent at the front as the warm air generated from proximity to the engine will get into the lenses (through a poor bulb holder/lens assembly seal maybe) and then creates the condensation when it encounters the rush of colder air from the front as you drive??
I took all my original front and rear lenses off recently (6 year old td5) to clean/grease the electrical contacts. I didn't encounter any condensation issues but I did have the same flimsy foam seal you mention. I smeared a bit of ACF50 grease (the blue stuff - don't believe that this will degrade the foam) around the seal when re-assembling. Wasn't really thinking of condensation, just to improve the overall seal against the elements. May be worth a go to try to combat the condensation issue too ? Jon - 110 td5 [sold]. Currently Defenderless. |
8th Nov 2011 10:47pm |
