Home > For Sale & Wanted > [For Sale] Second Row Door Check Strap Kit/Parts
rallysteve
I have a surplus kit from SP4x4 for RH second row door, as per https://www.sp-4x4.com/BFH710150_p/jwp1408.htm . All still in packages.
£15 posted or £10 collected from M1 J31
Also have a pair of the brackets which fit to the rear footwell kickplate which the second row door checkstraps attach to. Both brand new in package (MRC4753 & MRC4754).
£10 posted or £5 collected from M1 J31
Cheers,
Steve
 02' 110 TD5 Double Cab Rebuild Thread
Post #1020044 3rd Jan 2024 11:23pm
hxk494
Could I take the check strap please - subject to checking dimensions of it please?
I think the later doors had longer straps than earlier, would you be able to measure from centre of pivot roller to fixing hole for me please?
Many thanks,
Martin 1996 300Tdi Defender 110
Post #1020156 4th Jan 2024 10:28pm
rallysteve
Hi Martin,
No problem, i will measure for you, the parts catalogue shows the same part numbers (BFH710140/BFH710150) for both older and newer doors (1987-2016) though.
Cheers,
Post #1020183 5th Jan 2024 10:07am
hxk494
thanks Steve, much appreciated.
I know part # covers both new and old but I've got new style doors and old check straps fitted and I'm convinced they don't open as far as they used to/should.
No rush for the info.
Martin. 1996 300Tdi Defender 110
Post #1020217 5th Jan 2024 3:29pm
rallysteve
Afternoon,
Measured it today and its approx 195mm centre to centre (not measuring along the curved arm). If that helps?
Cheers,
Steve
Post #1020379 7th Jan 2024 2:54pm
hxk494
Thanks, just checked mine and they appear to be 185mm so not quite sure what’s going on there.
Not sure if 10mm difference will do much to door opening, think perhaps I’ll look I to the door opening extension kits the likes of YRM sell - that would cover both sides for a similar price with hopefully guaranteed results!
Appreciate you measuring but think I’ll pass on this occasion
Post #1020415 7th Jan 2024 6:56pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
Steve,
If Martin is "out", could i take these bits, please?
Thank you.
Post #1023484 3rd Feb 2024 8:10pm
julian
Just got the door parts in the post - all looks good.
Thanks to @rallysteve for a smooth transaction.
Post #1024791 15th Feb 2024 2:29pm
