Home > For Sale & Wanted > [Wanted] TD5 Air conditioning kit
PoormansXS
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
After an air conditioning kit for a TD5 all things considered.
Thanks
Post #1016309 25th Nov 2023 3:03am
geobloke
I have a complete TD5 AC kit from Cool Air Logan sitting in my utility room at the moment. I took it off Miffy back in the summer and just haven't got it listed yet.
https://www.coolairlogan.co.uk/land-rover-air-con
The kit is made for the TD5 but can actually be fitted to any pre-Puma Defender as it can be modified to work via simple relays rather than being fitted into the TD5 loom. Whilst removing the kit I cut nothing, all the pins are present ready to be slotted into the appropriate connector. The kit will fit behind a standard non-AC front grill and infant of an uprated intercooler.
Kt includes:
Compressor
AC lines
Condenser
Wiring loom
Lower dash
Fitting kit
Original Cool Air booklet
1x brand new Dayco Ac belt and 1x part used Dayco belt.
This is the equivalent kit https://www.lrparts.net/da2342r-land-rover...tment.html
I am a hike from you but do periodically head over to Nottingham so might be able to get it that far.
I can throw up some images of the kit if you are interested. Thumbs Up
Post #1016322 25th Nov 2023 10:05am
PoormansXS
Wow! I’m a new member so it won’t let me message you, just name your price!
Post #1016328 25th Nov 2023 11:32am
PoormansXS
Kt includes:
Compressor
AC lines
Condenser
Wiring loom
Lower dash
Fitting kit
It would definitely be handy if you’re able to get it to Nottingham on your next trip though. I’m in no rush it’s pretty bloody cold out at the moment 🤣
Post #1016426 26th Nov 2023 3:44pm
