![]() | Home > For Sale & Wanted > [Wanted] TD5 Air conditioning kit |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 58 ![]() ![]() ![]() |
After an air conditioning kit for a TD5 all things considered.
Thanks |
I have a complete TD5 AC kit from Cool Air Logan sitting in my utility room at the moment. I took it off Miffy back in the summer and just haven't got it listed yet.
https://www.coolairlogan.co.uk/land-rover-air-con The kit is made for the TD5 but can actually be fitted to any pre-Puma Defender as it can be modified to work via simple relays rather than being fitted into the TD5 loom. Whilst removing the kit I cut nothing, all the pins are present ready to be slotted into the appropriate connector. The kit will fit behind a standard non-AC front grill and infant of an uprated intercooler. Kt includes: Compressor AC lines Condenser Wiring loom Lower dash Fitting kit Original Cool Air booklet 1x brand new Dayco Ac belt and 1x part used Dayco belt. This is the equivalent kit https://www.lrparts.net/da2342r-land-rover...tment.html I am a hike from you but do periodically head over to Nottingham so might be able to get it that far. I can throw up some images of the kit if you are interested. ![]() |
Wow! I’m a new member so it won’t let me message you, just name your price!
It would definitely be handy if you’re able to get it to Nottingham on your next trip though. I’m in no rush it’s pretty bloody cold out at the moment 🤣 |
