![]() | Home > In Car Electronics > Focal V2 speaker install questions |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
I have read a few threads about installing these with the cross overs but just to confirm is it ok to use the existing speaker wires to power the cross over and then what wire should I use from the cross over to the speaker and tweeter? Audio isn’t really my thing
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Just had a look at this, so there are two wires to each of the main speaker connectors, and I assume one from each goes up to the tweeter? Do I connect all 4 to the cross over?? Andy
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
Basically yes. The crossover will be marked input, tweeter and mid. So find which 2 are connected to the tweeter, attach a string line to them so you can pull it up when you remove the tweeter, attache the new tweeter wire and pull down. Then connect the other 2 wires to the input on the crossover. New wire to the mid and away you go
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
The factory tweeters have their crossover/filter built in, so they are simply piggybacked off the main speaker.
To use crossovers, easiest to take the factory wires to the main speaker and use those as the input to the crossover. New wires from crossover to mid speaker, new wires from crossover to tweeter. Tape up the now unused factory tweeter plug somewhere safe for the future if you return to standard. ![]() ![]() |
