![]() | Home > Technical > 110 Station wagon small rear window trims securing |
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 189 ![]() ![]() ![]() |
Looks right to me i cant remember there being a fixing of any sort on the inside edge, should be tucked behind the side panel trim and then pushed into place near the door?
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 242 ![]() ![]() ![]() |
I dropped one of these the other day fitting window guards. Found it the next day and didn't have to order any, but had found the following
The Part number is MWC6203 which is superseded by BTR6682 https://www.lrworkshop.com/diagrams/land-r...trim_53578 Part number 14 in the above diagram ![]() They are spring loaded and clip on to the trim panel but simply grip the door frame. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
What is said above. The barbed part of BTR6682 fits onto a fat saddle that is riveted to the trim.
At least, thats how it is on a Puma. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
