![]() | Home > General & Technical (L663) > How low can you go? |
lrFFM Member Since: 28 Sep 2017 Location: Frankfurt Posts: 76 ![]() ![]() ![]() |
I drive the P525 and once the remaining range hits 0 miles, I have around 10 litres left in the tank. According to my dealer, the diesel engines have around 5 litres left once it shows 0.
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 291 ![]() ![]() |
I have a MY22 110 D300
Drove 41km/25 miles with 0 indicated on the dash at an indicated 100km/h (62mph) which consumed 2.9 litres of diesel. Went straight to the petrol station and put in 90.4 litres of diesel. LR spec sheet says fuel tank is 89L.. so I would say I didn't have much left. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 141 ![]() ![]() |
Not sure about the new ingenium diesels, the 2.7 and 3.0 TD and SD V6s did not like running out of fuel. The system needed 5 to 7l of fuel to prime the system, if you ran out, the potential was that you could drain the battery trying to crank it, leading to all sorts of BMS and EFI module issues. Lowest I had my D4 was fuel light flashing, range 30km, towing a camper across Australia. Reached Kimba South Australia with just over 5l in the tank. On the new L663, lowest I've let it get is just on the red zone. Currently averaging 10.9l/100km by the trip meter, 6900km on the clock, about 720km from a tank of fuel. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
I try avoid the tank being less than half and no lower than 1/4
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Oddly I'm the same. Never know when I will need to get up and go. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1307 ![]() ![]() |
![]() Click image to enlarge on a previous LR, it went to 0.0 as I entered the filling station. . |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3513 ![]() ![]() |
My last road trip I done 643 miles on a tank, that’s taking into account the 90 mile range I had left when I fuelled up. The 1/4 is as low as I go. 24MY 90 D250 HSE, Tasman Blue
My approach struggles alot more on the 5l (although means it feels like im not putting as much in) so its nice to use the diesel
