Home > General & Technical (L663) > How low can you go?
lightning
How low can you go?
How low on fuel have you dared to go?
Driving back from Wales yesterday the low fuel light was on, and it said range 23 miles. Eventually it dropped to 7 miles and the satnav was trying to lead me to fuel stations.
l reached the local one with 2 miles range remaining. l wonder how much was left? l don't know if the 3.0 diesel will self prime if it's run out of fuel, on my old TD5 you could initiate a "purge" mode that would re pressurise the fuel rail and remove air.
lt was useful when you'd replaced the fuel filter.
Post #1011604 17th Oct 2023 8:21pm
lrFFM
Germany 2016 Defender 90 Puma 2.2 SW Keswick Green
I drive the P525 and once the remaining range hits 0 miles, I have around 10 litres left in the tank. According to my dealer, the diesel engines have around 5 litres left once it shows 0.
Post #1011607 17th Oct 2023 9:12pm
haymeister
Japan
I have a MY22 110 D300
Drove 41km/25 miles with 0 indicated on the dash at an indicated 100km/h (62mph) which consumed 2.9 litres of diesel.
Went straight to the petrol station and put in 90.4 litres of diesel.
LR spec sheet says fuel tank is 89L.. so I would say I didn't have much left. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1011628 18th Oct 2023 1:05am
DFNDER
Australia
Re: How low can you go?
Not sure about the new ingenium diesels, the 2.7 and 3.0 TD and SD V6s did not like running out of fuel. The system needed 5 to 7l of fuel to prime the system, if you ran out, the potential was that you could drain the battery trying to crank it, leading to all sorts of BMS and EFI module issues.
Lowest I had my D4 was fuel light flashing, range 30km, towing a camper across Australia. Reached Kimba South Australia with just over 5l in the tank.
On the new L663, lowest I've let it get is just on the red zone. Currently averaging 10.9l/100km by the trip meter, 6900km on the clock, about 720km from a tank of fuel.
Post #1011637 18th Oct 2023 8:08am
mse
I try avoid the tank being less than half and no lower than 1/4 Rolling with laughter Mike
Post #1011662 18th Oct 2023 12:41pm
Moo
Ukraine
Oddly I'm the same. Never know when I will need to get up and go. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1011663 18th Oct 2023 12:46pm
LR Nuts
on a previous LR, it went to 0.0 as I entered the filling station.
Post #1011664 18th Oct 2023 1:00pm
J77
My last road trip I done 643 miles on a tank, that’s taking into account the 90 mile range I had left when I fuelled up. The 1/4 is as low as I go. 24MY 90 D250 HSE, Tasman Blue
Post #1011666 18th Oct 2023 1:30pm
mse
My approach struggles alot more on the 5l (although means it feels like im not putting as much in) so its nice to use the diesel Rolling with laughter Mike
Post #1011672 18th Oct 2023 3:04pm
