Home > Maintenance & Modifications > ? Battery
Stiff1
? Battery
So had a flat battery at the weekend after not using the Landy for a few weeks, never been a problem before.
Jump started it, which took a good while of running off a 1.4 Fiesta and set about a lovely drive for about 1hr 30, a lot at 60+.
Got home turned off , restarted which it labored and then nothing this morning.
So battery or alternator?
Post #1002403 31st Jul 2023 1:41pm
Chicken Drumstick
I could take a guess, it's 50:50, but no way to know based on that info.
Easiest way is to get it started, put a multi meter over the terminals and see if you are getting 13.5+ volts, if you are the alternator is probably fine.
What vehicle are you talking about too might help..... not all engines and alternators have been the same since 1948 Laughing
Post #1002406 31st Jul 2023 1:48pm
Stiff1
Puma 2.4
Post #1002407 31st Jul 2023 1:50pm
Dinnu
As long as the battery is connected, there is always a current draw on modern cars and Defenders. Thats to keep clocks, alarms etc running.
Lead acid batteries do not like going under 12.4V, and probably that caused permanent damage to the battery.
There are a lot of cheap gadgets that go in the cigarette lighter and display the battery voltage. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1002434 31st Jul 2023 4:20pm
Rupert605
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Cold Cranking Amps are more important than voltage - a battery can be charged up and displaying 13.5v yet give problems starting if it has deteriorated over time. If you can get your hands on something like a Topdon BT50 batter tester this will perform a cranking test and tell you if the battery needs replacing.
Rupert Defender 50th GB165
Discovery 200 Tdi 1990 (gone)
Post #1002444 31st Jul 2023 5:31pm
Stiff1
Thanks all, I'll let you know how I get on
Post #1002456 31st Jul 2023 7:53pm
