![]() | Home > Puma (Tdci) > Rocker valve assembly |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
LR004443 Same part, check there’s not more damage. Exhaust camshaft is different between 2.2 and 2.4- inlet is the same.
Antonva Member Since: 29 Jul 2023 Location: western cape Posts: 4 ![]() ![]() ![]() |
Ok. Thx. The parts list I've attached was from the local repairer that stripped the engine.
So I believe that's the only damage. Hopefully |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
You also need injector washers. Make sure the injector seats are clean. However, I am not sure if you need to remove the injectors. Puma 110" SW
I would carefully check the cam shafts and the housings, also the timing chain tensioner as to how far out it is.
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 203 ![]() ![]() ![]() |
When I had the rocker assembly and exhaust camshaft failing on my 2.4 earlier in the year, I got most of my replacement parts from https://www.turnerengineering.co.uk/ as you can select your vehicle in a drop down list to choose parts, hence don’t really need to bother with part numbers. Plus I know that they sell quality parts, as they are the same they use in their engine rebuilt, either true OEM or Ford, and much cheaper than from JLR.
/Mat |
Turners and Auntie Frida are the best
Thx everyone. For your inputs. Will definitely follow all of the advice. Will also check out the UK spares and see how much it will work out to import compared to what it will cost here.
Is Auntie Frida also a parts supplier company?
Sorry that’s a joke-
Frida owns Turner Engineering with her husband Richard. |
