Home > Puma (Tdci) > Rocker valve assembly
Antonva
South Africa 2010 Defender 110 Puma 2.4 PU Bronze Green
Hi All,
I have a broken rocker valve assembly. As we all know the Puma engine is a ford engine. I've got the 2.4 engine and would like to know what is the difference between the 2,4 and the 2,2 engine as all my searches for the ford replacement part is for a ford 2.2 engine.
When engine was stripped it was noticed that the engine was stripped before, so I am afraid to buy the exact parts as per the ford part numbers on the old rocker valve assembly and perhaps make the same mistake the previous repairers made.
Regards
Post #1002218 29th Jul 2023 9:58pm
NickMc
LR004443 Same part, check there’s not more damage. Exhaust camshaft is different between 2.2 and 2.4- inlet is the same.
Post #1002285 30th Jul 2023 2:49pm
Antonva
Ok. Thx. The parts list I've attached was from the local repairer that stripped the engine.
So I believe that's the only damage. Hopefully
Post #1002324 30th Jul 2023 9:48pm
MK
You also need injector washers. Make sure the injector seats are clean. However, I am not sure if you need to remove the injectors. Puma 110" SW
Post #1002453 31st Jul 2023 8:15pm
NickMc
I would carefully check the cam shafts and the housings, also the timing chain tensioner as to how far out it is.
Post #1002471 31st Jul 2023 10:56pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
When I had the rocker assembly and exhaust camshaft failing on my 2.4 earlier in the year, I got most of my replacement parts from https://www.turnerengineering.co.uk/ as you can select your vehicle in a drop down list to choose parts, hence don’t really need to bother with part numbers. Plus I know that they sell quality parts, as they are the same they use in their engine rebuilt, either true OEM or Ford, and much cheaper than from JLR.
/Mat
Post #1002564 1st Aug 2023 6:41pm
NickMc
Turners and Auntie Frida are the best Thumbs Up
Post #1002583 1st Aug 2023 8:09pm
Antonva
Thx everyone. For your inputs. Will definitely follow all of the advice. Will also check out the UK spares and see how much it will work out to import compared to what it will cost here.
Post #1003501 9th Aug 2023 6:32pm
Antonva
Is Auntie Frida also a parts supplier company?
Post #1003503 9th Aug 2023 6:42pm
NickMc
Sorry that’s a joke-
Frida owns Turner Engineering with her husband Richard.
Post #1003523 9th Aug 2023 8:09pm
