![]() | Home > Maintenance & Modifications > To bleed or reverse bleed the clutch |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983 ![]() ![]() ![]() |
I normally drain the clutch cylinder with a large syringe clean all the crud from it and then refill with fresh fluid. Then I bleed the system until clean new fluid comes out.
Jim |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1304 ![]() ![]() ![]() |
I found on a Range Rover classic I never got it to bleed right, so in the end I just crawled underneath, removed the slave from the bell housing, held it pointing down and just pushed the plunger fully in a few times to purch the air out through the reservoir. Both master, hose and slave were new
