Home > Maintenance & Modifications > To bleed or reverse bleed the clutch
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Something Hamlet would say but....
Clutch pedal feels funny sporadically. Brake master cylinder is full so no fluid leaks
Thinking of bleeding the clutch - should I start off with bleeding from the bleed nipple or reverse bleeding with a pump thingy?
Post #1001080 21st Jul 2023 11:24am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
I normally drain the clutch cylinder with a large syringe clean all the crud from it and then refill with fresh fluid. Then I bleed the system until clean new fluid comes out.
Jim
Post #1001102 21st Jul 2023 2:32pm
kmac
Thumbs Up
Post #1001126 21st Jul 2023 5:34pm
TexasRover
I found on a Range Rover classic I never got it to bleed right, so in the end I just crawled underneath, removed the slave from the bell housing, held it pointing down and just pushed the plunger fully in a few times to purch the air out through the reservoir. Both master, hose and slave were new
Post #1001168 21st Jul 2023 9:48pm
