Home > Technical > Slam panels AC versus non AC
geobloke
Curious to know whether there is actually an AC and non-AC slam panel?!
And what are the differences between them if there are?!
Cheers Thumbs Up
Post #1000269 15th Jul 2023 4:18pm
Dinnu
I refurbished both my Puma with AC slam panel, and my 1988 without AC of course and they look very similar, if not identical. But on the Puma it has an additional bracket, with 4 rivets mounted to the slam panel which the earlier Landrover did not have. I do not think that is AC specific though.
Adding some photos from my puma with AC, maybe they help
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1000276 15th Jul 2023 5:25pm
NickMc
That’s for the bonnet cable to mount and I think it was a security “update”
Post #1000278 15th Jul 2023 5:28pm
^^^ I remember that as well.
Post #1000293 15th Jul 2023 7:00pm
geobloke
Ah so the AC version isn't wider to accommodate the sticky out nose/grille then!?!
Post #1000295 15th Jul 2023 7:02pm
rustandoil
The panel in those pictures looks very similar to my 2005 TD5 aircon.
Post #1000296 15th Jul 2023 7:03pm
Dinnu
Maybe visible in the 3rd picture, but there are thick washers between the mudguard and the slam panel on the Puma with AC. There are no washers on the 1988 model without AC. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1000298 15th Jul 2023 7:13pm
rustandoil
Yes, thick washers on my TD5, I don't know their purpose but they're there.
Post #1000303 15th Jul 2023 7:27pm
Thick washers = LR's build tolerance adjustment Laughing
Post #1000384 16th Jul 2023 2:50pm
Dinnu
^^ hahaa….Me too wondered, especially since there are no washers where the mudguards attach to the chassis. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1000394 16th Jul 2023 3:42pm
Oldowner
The thick washers came when Land Rover rammed the inter cooler mounts in between the slam panel and the wings in 1998, without redesigning the slam panel, causing the wings to splay outwards at the top. What they really shouldve done was to fit the washers on the lower mounts to level the wings up again instead of hoping no-one would notice the droopy wings from the front.
Answer to original question is same slam panel used AC or non AC. Just addition of two small tab brackets on inner face of wings to accommodate the AC nose
Post #1000544 17th Jul 2023 3:57pm
geobloke
Marvellous. Many thanks all for the info Thumbs Up
Post #1000565 17th Jul 2023 5:30pm
