![]() | Home > Technical > Slam panels AC versus non AC |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Curious to know whether there is actually an AC and non-AC slam panel?!
And what are the differences between them if there are?! Cheers |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
That’s for the bonnet cable to mount and I think it was a security “update”
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
^^^ I remember that as well.
Ah so the AC version isn't wider to accommodate the sticky out nose/grille then!?!
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
The panel in those pictures looks very similar to my 2005 TD5 aircon.
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3646
Maybe visible in the 3rd picture, but there are thick washers between the mudguard and the slam panel on the Puma with AC. There are no washers on the 1988 model without AC. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Yes, thick washers on my TD5, I don't know their purpose but they're there.
Thick washers = LR's build tolerance adjustment
^^ hahaa….Me too wondered, especially since there are no washers where the mudguards attach to the chassis. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683
The thick washers came when Land Rover rammed the inter cooler mounts in between the slam panel and the wings in 1998, without redesigning the slam panel, causing the wings to splay outwards at the top. What they really shouldve done was to fit the washers on the lower mounts to level the wings up again instead of hoping no-one would notice the droopy wings from the front.
Answer to original question is same slam panel used AC or non AC. Just addition of two small tab brackets on inner face of wings to accommodate the AC nose |
Marvellous. Many thanks all for the info
