Home > For Sale & Wanted > [SORTED] Cable tie base mounts x6
geobloke
I need 6 of these cable tie mounts, just 6... Not 100 or 200...
By chance does anyone have a bag of these and wouldn't miss 6 of them??
https://www.amazon.co.uk/gp/product/B07ZKN...&psc=1
These little bases:
Many thanks Thumbs Up
Post #999467 10th Jul 2023 1:52pm
Ianh
If no one has any for you B and Q do in 25’s for a couple of quid.
Post #999481 10th Jul 2023 2:29pm
geobloke
Thanks Ian Thumbs Up I did not know they did them. The nearest BandQ to me is about 45 mins away, living in the boon-docks has its down sides Rolling Eyes Rolling with laughter
Post #999484 10th Jul 2023 2:32pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I have some self adhesive cable tie mounts if they would be any good?
I'm sure it would be possible to drill them and put a small self tapping screw through if necessary. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #999499 10th Jul 2023 4:18pm
geobloke
Thanks Phill. I really should have said Rolling Eyes These are going behind the bumper in the void to fix the cabling to the DRL/fog lights so have to be screwed down and not made just to rust at the first experience of Welsh weather.
Do you think there is enough material in your bases to drill out?
Post #999502 10th Jul 2023 4:30pm
donmacn
I bought some of these recently in small/sensible quantities from either 12Voltplanet, or autoelectricalsupplies.... or something like that. If it's still something you need then let me know and I can try and pin down the website. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #999504 10th Jul 2023 4:45pm
DAZ110
I have some, they look the same size as your Amazon link.
I slid a 4.8mm cable tie through it a moment ago.
Send me your postal address and will get them on the way to you asap.
Post #999507 10th Jul 2023 4:49pm
geobloke
Essex is a long way away from here, but I could kiss you Daz... Rolling with laughter Shocked
That is exactly what I am after. PM on the way. Thumbs Up Thumbs Up Thumbs Up
Post #999508 10th Jul 2023 4:54pm
DAZ110
It’s Sussex actually, bit posher than Essex. Whistle Laughing
No problem, will get them posted.
Post #999509 10th Jul 2023 4:58pm
geobloke
Oh well if it is Sussex then I'd take you to dinner (somewhere posh of course) first, then kiss you Rolling Eyes Rolling with laughter
Post #999510 10th Jul 2023 5:00pm
DAZ110
Sounds good to me. Wink Thumbs Up Rolling with laughter
Post #999513 10th Jul 2023 5:07pm
Dinnu
If you do not mind drilling, then another option is to drill 2 holes, 10mm (or less) apart, and then pass a cable tie through the holes such that the cable tie clamps the wire. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999514 10th Jul 2023 5:11pm
Ianh
Hurtful Rolling with laughter
Post #999529 10th Jul 2023 7:23pm
Screbble
But true?
Post #999532 10th Jul 2023 7:38pm
PaulMc
Too late now, but for anyone else looking -
https://www.polevolt.co.uk/acatalog/Cable_Ties___Fixings.html
Cable Tie Cradle small 4.8mm. Fixing hole 3.8mm. 10 pack. Ref: CTC1/10
Cable Tie Cradle large 7.8mm. Fixing hole 5.0mm. 10 pack. Ref: CTC2/10
Also - https://www.autoelectricsupplies.co.uk/product/335/category/65
. Paul.
Post #999570 10th Jul 2023 10:12pm
