![]() | Home > For Sale & Wanted > [SORTED] Cable tie base mounts x6 |
I need 6 of these cable tie mounts, just 6... Not 100 or 200...
By chance does anyone have a bag of these and wouldn't miss 6 of them?? https://www.amazon.co.uk/gp/product/B07ZKN...&psc=1 These little bases: ![]() Many thanks ![]() Last edited by geobloke on 13th Jul 2023 9:29am. Edited 1 time in total |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2424 ![]() ![]() |
If no one has any for you B and Q do in 25’s for a couple of quid.
Thanks Ian
Thanks Phill. I really should have said
![]() Do you think there is enough material in your bases to drill out? |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1887 ![]() ![]() |
I bought some of these recently in small/sensible quantities from either 12Voltplanet, or autoelectricalsupplies.... or something like that. If it's still something you need then let me know and I can try and pin down the website. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2064 ![]() ![]() |
I have some, they look the same size as your Amazon link.
I slid a 4.8mm cable tie through it a moment ago. ![]() Click image to enlarge Send me your postal address and will get them on the way to you asap. |
Essex is a long way away from here, but I could kiss you Daz...
![]() ![]() That is exactly what I am after. PM on the way. ![]() ![]() ![]() |
It’s Sussex actually, bit posher than Essex.
![]() ![]() No problem, will get them posted. |
Oh well if it is Sussex then I'd take you to dinner (somewhere posh of course) first, then kiss you
Sounds good to me.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
If you do not mind drilling, then another option is to drill 2 holes, 10mm (or less) apart, and then pass a cable tie through the holes such that the cable tie clamps the wire. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Hurtful ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
But true?
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Too late now, but for anyone else looking -
https://www.polevolt.co.uk/acatalog/Cable_Ties___Fixings.html Cable Tie Cradle small 4.8mm. Fixing hole 3.8mm. 10 pack. Ref: CTC1/10 ![]() Cable Tie Cradle large 7.8mm. Fixing hole 5.0mm. 10 pack. Ref: CTC2/10 ![]() Also - https://www.autoelectricsupplies.co.uk/product/335/category/65 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
