![]() | Home > In Car Electronics > Wiring auxillary power outlets on Td5 centre dash |
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868
I've just done similar, I mounted a 4 way fuse box in the battery compartment, this fuse box is made "accessory live" via a relay triggered off the back of the head unit.... A similar fuse that wired directly off the battery is also mounted in the battery compartment.
| DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 269
Thanks Rustandoil.
Could you expand on relay type? Did you route wires under transmission carpet? Cheers |
I used a standard 4 pin relay from Vehicle Wiring Products... That's where i get all my electrical parts from.
And yes i have run the RCA wires and relay trigger wire in sleeving under the transmission carpet. Mines a 110 so the dub aI will take a picture if you think it will help? Mines a 110, so the RCA and Sub wires carry on under the rear floor carpet to under the rear seat, relay trigger wires exit the cab through a grommet under the cubby box and into the battery box. |
Thanks again.
A photo would be really useful if not a problem. Just trying to decide whether to mount sub under cubby in a mud stuff box or under rear seat.. Cheers Rob |
Here you go....a bunch of pics that might convey the way i did my aux wiring re-fresh
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
