Home > In Car Electronics > Wiring auxillary power outlets on Td5 centre dash
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
I’m replacing my radio and whilst Td5 centre dash console is out I want to wire a perm. live to a sub woofer, usb and usb c charging points,
plus one other low load permanent live.
How do I best pick up a live/earth and split cable to power 4 outlets. Can I pick up from fuse board, use radio harness or best direct from battery via fuse board.
Many thanks
Post #998617 4th Jul 2023 7:31pm
rustandoil
I've just done similar, I mounted a 4 way fuse box in the battery compartment, this fuse box is made "accessory live" via a relay triggered off the back of the head unit.... A similar fuse that wired directly off the battery is also mounted in the battery compartment.
Post #998622 4th Jul 2023 7:44pm
DC101
Thanks Rustandoil.
Could you expand on relay type?
Did you route wires under transmission carpet?
Post #998650 4th Jul 2023 10:00pm
rustandoil
I used a standard 4 pin relay from Vehicle Wiring Products... That's where i get all my electrical parts from.
And yes i have run the RCA wires and relay trigger wire in sleeving under the transmission carpet.
Mines a 110 so the dub aI will take a picture if you think it will help?
Mines a 110, so the RCA and Sub wires carry on under the rear floor carpet to under the rear seat, relay trigger wires exit the cab through a grommet under the cubby box and into the battery box.
Post #998662 5th Jul 2023 5:51am
DC101
Thanks again.
A photo would be really useful if not a problem.
Just trying to decide whether to mount sub under cubby in a mud stuff box or under rear seat..
Rob
Post #998667 5th Jul 2023 7:29am
rustandoil
Here you go....a bunch of pics that might convey the way i did my aux wiring re-fresh
Post #998676 5th Jul 2023 9:01am
