Home > Puma (Tdci) > TDCi instrument cluster temporarily not working
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Changed my battery today, carefully, with no mishaps or untoward occurrences. (2008/2.4)
When I started the car, most of the instrument cluster was not working: nothing from the gauges, odometer or some of the warning lights - but alarm, indicators, headlamp and handbrake lights all fine. All other electrics seemed to be functioning correctly. The car started fine and was driveable (using Torque Pro to view speed/revs/temp) - but there seemed to be a loss of performance similar to, but not the same as, limp home mode. No MIL showing of course, but read fault code U0155 (communication lost with instrument cluster).
Looked at fuses, tried restarting a few times and clearing the fault code, and had a look at this thread:
https://www.defender2.net/forum/topic74893.html
All to no avail.
Disconnected the battery, left it for an hour, reconnected the battery. All is now well.
Has anyone else encountered this? If it just needs a further 'reboot' occasionally after the battery is disconnected, no worries. I've not experienced it before however, and if it is a sign of imminent failure, it would be good to pre-empt the evil day.
In fact, if it weren't for the loss of performance, the only immediate issue was loss of the fuel gauge, which I don't think can be replicated via OBD and Torque Pro?
Post #998569 4th Jul 2023 4:15pm
wyvern
I had this happen when on a trip in France over the xmas period. Lost the whole instrument cluster with no warning lights or gauges. Plugged in my fault reader but no faults found
Took the dash to bits, checked all the plugs fuses relays wiring etc but could not find the issue.
The vehicle worked fine and drove normally, so set up my satnav as a speedo and drove to garage to see if they could find the fault - they pointed me to another garage which was a landrover specialist,
However when we got back in and turned on the ignition all was back to normal ... !!
No issues since !
having searched on here I have found that this fault has happened to several people in the past with the same results ... no fault but it sorted its self out after a while (2 hrs in my case ...)
So I put it down as a landrover defender gremlin ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #998576 4th Jul 2023 4:56pm
NickMc
I’ve reflowed the solder on many of these Tdci clusters where they’ve cracked at the plug on the pcb
Post #998609 4th Jul 2023 6:57pm
dferrandi
South Africa
Had this happen to me in Mozambique in my 2.4 Puma. Fairly scary having an idling car and absolutely no life on the instrument panel!
The solution for me was as follows:
I had been tinkering with the battery and in the process a very thin little cord had come loose (off the positive terminal if I recall).
This wire has a little clip that it fits into on the red terminal which can become worn and frayed.
Once I found this loose and dangling wire, I clipped it back in and the instrument panel immediately came to life.
Now if your problem is intermittent, could it be that this cord / connector is a bit frayed and therefore it decides when it will connect vs not?
Hope this also works for you…fortunately a very simple fix!
Post #999149 8th Jul 2023 5:48am
JWBW
United Kingdom 2007 Defender 110 Puma 2.4 HT Caledonian Blue
I recently took my battery out for an unrelated thing and then replaced it and found this issue but didn't have time to look into it until now. Had to drive somewhere on a hope and a prayer. disconnect the battery for an hour and a half like a couple of you have said as that seemed the simplest thing to do for now and like you've said it seems to have fixed the issue, so thank you for sharing this almost took it to a garage or bought a new cluster!
Post #1070333 25th Jun 2025 10:58pm
