Home > Technical > Wabco ABS Pump - please help me to a conclusion - 2.4 Puma
Page 2 of 2 <12
andyped
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
ABS died
DuncanS wrote:
I had the same thing, but it wouldn't go away frustratingly, however one afternoon and a £30 Disco 2 ABS pump and we were back on the road.
Hi DuncanS, I'm facing the same issue, can't find LR055940 at any sensible price. I wondered if you had any issues after your Disco 2 hack and if you had any advice?
Post #1065461 14th Apr 2025 11:57am
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
straight swap, just ignore the labeling of the ports and connect it up in the exact same way as your old unit came off. you'll need a diagnostic tool that can do the ABS power bleeding to each wheel.
Post #1065570 15th Apr 2025 11:49am
glpinxit
I had a similar thing with the ABS when I had a TD5 Defender. At the time I had the original Nanocom unit and I used it to run the ABS pump which sounded sluggish. Thinking there was nothing to lose I used the Nanocom to run the pump on each wheel in turn and after going round them all a couple of times the pump was running much faster and more smoothly. When the problem returned a few months later I put a reminder in my diary to cycle the pump every two months and all was well for several more years after which I replaced the Defender. Cheers, Guy.
Post #1066034 22nd Apr 2025 9:18am
Page 2 of 2 <12
