Home > Maintenance & Modifications > Puma steering box
NorthernDefender90
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Puma steering box
Hi All,
I have a 2007 defender puma, my steering box has a bad leak, when looking at replacements there is 3,4,6 bolt steering boxes. I have no idea which I have, is it dependent on year, spec?
If anyone knows either; how to find out or just knows which the puma defenders have it would be greatly appreciated.
Post #996837 19th Jun 2023 11:57am
rallysteve
If you look at the top of the box from under the bonnet you will see it will be triangular (with three bolts in the corners), square (with four bolts in the corners) or hexagonal (with 6 bolts in the corners).
I am 99% certain it will be a four bolt version though (also often referred to as Adwest lightweight) as all of the other versions I have seen on much older variants.
Cheers,
Post #996840 19th Jun 2023 1:02pm
NorthernDefender90
Amazing, thanks so much for your help.
Post #996841 19th Jun 2023 1:10pm
