![]() | Home > Maintenance & Modifications > Puma steering box |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
If you look at the top of the box from under the bonnet you will see it will be triangular (with three bolts in the corners), square (with four bolts in the corners) or hexagonal (with 6 bolts in the corners).
I am 99% certain it will be a four bolt version though (also often referred to as Adwest lightweight) as all of the other versions I have seen on much older variants. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
NorthernDefender90 Member Since: 19 Aug 2021 Location: Leeds Posts: 13 ![]() ![]() ![]() |
Amazing, thanks so much for your help.
