![]() | Home > Expedition & Overland > Engel fridge power socket query |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
Hi all, fitting auxiliary battery in the 130, I want to power the Engel fridge directly from a board in the rear, not the cigarette lighter.
No problem you think, just source a plug and wire it into the board, but my issue is I can only buy a +/-£50 power lead to chop the socket off..! It’s a 3 pin jobby and I can’t find it anywhere online, anyone any idea where I can get one? I want to keep the original for future use in other vehicles.. Cheers Alex ![]() Click image to enlarge 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 106 ![]() ![]() ![]() |
One way is to cut your current cable and fit plug and socket on to cut ends and then make up second cable that will fit onto engel section of your original cable and to your board. You will need 2+1 plug/sockets so depends on price for those. Andy
1996 300TDI 110 SW 2013 TDCI 110 Utility |
Hi, yes I’ve kind of figured that would be the best way realistically, I’ve spent ages trying to find the bloody things! All I’ve found is other people asking the same!
What connectors would be best you reckon?.. Cheers Alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
GAT Member Since: 20 Apr 2013 Location: Kent Posts: 131 ![]() ![]() |
Would something like this do?
https://www.ebay.co.uk/itm/394158002613?va...VMEALw_wcB First Edition 90 in Pangea Green. (Gone) P400 110 in Tasman Blue. |
Thanks gat, I saw that but was worried that although the main picture looks like my plug, the subsequent images are different! I’ve messaged them to finf out, would be perfect if so..
!.. Cheers alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
Ordered the ebay one so we will see..!
Cheers guys 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
