![]() | Home > Maintenance & Modifications > Gear change much improved |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
The Puma capacity id 2.4 litres when new, but 2.2 litres for an oil change ... there must be 0.2litres left in there when you remove the drain.
No the filler is not a level plug. Only way to measure the oil is to take it out & measure it. Some members on this forum measured the level below the filler IIRC, and it was just a few mm - so maybe the dealer knows it should be a cetrain level under the filler and did it that way? PS my gearbox is the same, you need to change from 2nd to 3rd really slowly for it to be smooth....not always easy uphill with a trailer - you can lose too much road speed, and make 3rd labour slightly (or overrev in 2nd first).. Maybe he just put some additives in there? It would be good to know! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
