![]() | Home > Maintenance & Modifications > Cunifer corroded 11 months! |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2763 ![]() ![]() |
It’s an alloy of several metals, including copper, nickel and indeed iron - so may well be magnetic.
I’ve never had one corrode, they go a bit green but never rusty. What brand did you use? |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
After seeing your post I just tried a magnet against my cunifer and there is no attraction between the two whatsoever. I don't know where you got your pipe but my thoughts are it ain't true cunifer.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
The pipe in your photo is not Cunifer, I'd say it is steel and not very high quality. Cunifer is non-magnetic.
I suspect you were sold counterfeit pipes. ![]() |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529 ![]() ![]() |
Not Kunifer it usually just goes green, we usually fit stainless unions and protect with Lanogaurd once fitted or alternativley fit the full pioneer braided stainless line kits.
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983 ![]() ![]() ![]() |
Just tried the magnet test on my brake pipes. No attraction at all and in far better condition than yours even though they must be 8 years+ old?
Jim |
I would use copper with an amount of caution. A bit to easy to bend and work harden. It's not used (as in not allowed) in some countries because this can lead to failure! I think that says enough really.
Some people use copper over cunifer as its easier to form, but that is at the cost of strength. Personally I would buy another coil of cunifer from a more reputable source. Note: when I was looking on ebay I found some brake pipe which I thought was cunifer but on reading the specification it said copper coated steel. Typically they somehow included the word cunifer in their description so easy to presume its cunifer and not the steel they actually sell!! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Easy to get had by the eBay sellers listing copper plated steel pipe as cunifer
![]() ![]() ![]() Last edited by Martin on 29th May 2023 8:37pm. Edited 1 time in total |
I replaced the brake pipes on my first 80" sometime around 1980 with Cunifer and they are still as good as new.
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Thanks for the reply’s
Just looked through my receipts and it’s itemised as Cunifer copper nickel brake line, clearly not! Reputable supplier too (not EBay or Amazon) but I expect all I will get if anything is a refund! Linds Hanson thanks for the tip I very well might go down the full Pioneer kit I have their hoses on which have had no issues with. 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Pioneer kit arrived this week and fitting it tomorrow, plus a brake overhaul and some painting 2023 Defender L663 V8
