Home > Maintenance & Modifications > Cunifer corroded 11 months!
bear100
Hi chaps
I changed all my brake lines due to a split one and corrosion on the original back last July.
I was advised by the majority to use cunifer/kunifer pipe, had my MOT done last week and corroded brake lines were picked up Shocked nonsense I thought.
Look under the car today and sure enough all the lines are in a worse condition to what I removed!
Put a magnet against them and they stuck so cunifer isn’t copper at all?
Looks like I will have to do them all again! But use pure copper this time I suppose? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #994403 29th May 2023 5:25pm
Retroanaconda
It’s an alloy of several metals, including copper, nickel and indeed iron - so may well be magnetic.
I’ve never had one corrode, they go a bit green but never rusty. What brand did you use?
Post #994408 29th May 2023 5:54pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
After seeing your post I just tried a magnet against my cunifer and there is no attraction between the two whatsoever. I don't know where you got your pipe but my thoughts are it ain't true cunifer.
Post #994413 29th May 2023 6:21pm
The pipe in your photo is not Cunifer, I'd say it is steel and not very high quality. Cunifer is non-magnetic.
I suspect you were sold counterfeit pipes. Sad
Post #994419 29th May 2023 6:55pm
Linds Hanson
Not Kunifer it usually just goes green, we usually fit stainless unions and protect with Lanogaurd once fitted or alternativley fit the full pioneer braided stainless line kits.
Post #994421 29th May 2023 7:05pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Just tried the magnet test on my brake pipes. No attraction at all and in far better condition than yours even though they must be 8 years+ old?
Jim
Post #994423 29th May 2023 7:35pm
Mossberg
I would use copper with an amount of caution. A bit to easy to bend and work harden. It's not used (as in not allowed) in some countries because this can lead to failure! I think that says enough really.
Some people use copper over cunifer as its easier to form, but that is at the cost of strength. Personally I would buy another coil of cunifer from a more reputable source.
Note: when I was looking on ebay I found some brake pipe which I thought was cunifer but on reading the specification it said copper coated steel. Typically they somehow included the word cunifer in their description so easy to presume its cunifer and not the steel they actually sell!!
Post #994425 29th May 2023 7:47pm
Martin
Site Admin
Easy to get had by the eBay sellers listing copper plated steel pipe as cunifer Evil or Very Mad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #994429 29th May 2023 8:32pm
I replaced the brake pipes on my first 80" sometime around 1980 with Cunifer and they are still as good as new.
Post #994430 29th May 2023 8:33pm
bear100
Thanks for the reply’s
Just looked through my receipts and it’s itemised as Cunifer copper nickel brake line, clearly not! Reputable supplier too (not EBay or Amazon) but I expect all I will get if anything is a refund!
Linds Hanson thanks for the tip I very well might go down the full Pioneer kit I have their hoses on which have had no issues with. 2023 Defender L663 V8
Post #994435 29th May 2023 9:28pm
bear100
Pioneer kit arrived this week and fitting it tomorrow, plus a brake overhaul and some painting 2023 Defender L663 V8
Post #996675 17th Jun 2023 11:13pm
