Home > Maintenance & Modifications > Removing factory axle breather |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
The ones on my TD5 didnt put up too much of a fight. I just used a small screwdriver under the edge to unseat them. They came out okay once they had unseated.
You could try using a section of the pipe to try and pull on it to see if it will shift. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
18th May 2023 8:41am |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 149 |
Belated thanks for the encouragement, rallysteve.
I eventually got it out by taking the wheel off and attacking from above with a sharp chisel. |
27th May 2023 3:40pm |
