![]() | Home > Td5 > TD5 CSW Seatbelt options |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1304 ![]() ![]() ![]() |
I might be mistaken but I believe the Td5 center seatbelts are lap belts (2 point), manually adjusted (static) only. They are bolted to the floor strengthened structure together with the latches for each side, so total of 4 attachments coming from 2 mounting points.
To have 3 point seatbelts in the middle I would think you require the middle seat to have the shoulder belt part (and associated strenght) as the there is no roof/frame attachment as far as I know. Probably that is what they did on the Puma as it have a significant anchor point for the seats in the floor. |
If I wanted to replace my (a bit ropy) seat belts at the back I would buy:
2x anchor point MXC7264 2x second row buckle MXC5521 1x center second row seat belt MXC5497 (says Series, but looks just like what I have. The above would get you a detachable set, the factory set does not have the hook, instead the anchor point attachment is fixed. |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
The Exmoor Trim Premium High Back seats are great but they sit higher than the standard 60:40 bench seat. Not an issue for the outer seat belts as the floor mounted buckle ends are just about long enough but the middle lap belt isn't long enough to secure an adult comfortably. I bought a seat belt extender from ebay which clicks into the buckle end and provides approx 12 inches of additional length.
A word to the wise, although it should be obvious. Fit the centre seat first after having measured at least twice to get it perfectly central. Then test fit the outer seats to get the right amount of space between them. You will need an assistant to hold bolts steady inside while you fasten nuts from underneath and if I were to do it again I'd ditch the fasteners that ET provide and use stainless nuts, bolts and washers. Also the seats fit to their bases with socket cap bolts (i.e. Allen headed bolts). They're a proper pain to fit and secure because the of the limited space between the seats to get the Allen key on. Better to use normal hex headed bolts because you can get a 13mm spanner on them. ![]() Click image to enlarge |
